I'm creating a movie trailer compilation from DVDs I own. After encoding a .VOB file as .MPG (DVD NTSC template) using MPEG Video Wizard and importing it into my DVD Architect project, I am left with video but no audio. The .MPG files play fine and with audio in Windows Media Player. Any suggestions? Thanks in advance.
I'm looking at MPEG Video Wizard's Export/Save As dialog box where I selected the DVD NTSC template. When I click on details, the audio section shows AC-3, 2 channels (for the X Files: Fight the Future trailer), 48 KHz, 192 Kbps. When I do the same thing for for House of Flying Daggers trailer, I see AC-3, 6 channels, 48 KHz, 384 Kbps.
Thanks! -
If MPEG Video Wizard isn't the right program to convert .VOB files to DVD complient .MPG files, can anyone suggest another tool?
Maybe I need to multiplex the .MPG files with TMPGENC. I'll try that tonight. -
You cannot mix different format audio or video in the same titleset, so 2 channel AC3 and 6 channel AC3 must be in seperate titlesets. If you try to mix them, and the authoring software may not stop you, the usual symptom is loss of audio as the playback device gets confused.
Read my blog here.
Why does Sony DVD architect blow up movie files so largely?
By smythotech in forum Authoring (DVD)Replies: 3Last Post: 17th Aug 2011, 18:52 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
MPG files play fine on computer, no audio on DVD player
By kenimpzoom in forum Newbie / General discussionsReplies: 9Last Post: 16th Feb 2010, 15:07 -
Importing subtitles into DVD Architect 4.0
By hurricane1951 in forum SubtitleReplies: 3Last Post: 14th Apr 2008, 17:44 -
Importing DVD Files for Use in Final Cut?
By The Monkees in forum MacReplies: 8Last Post: 29th Dec 2007, 10:20
